Status
Not open for further replies.
SSRT-S10
I am in process of creating a custom Xtreme Clone. I went through all of the part #'s here and found that some #'s have been changed or removed. Sooo I decided to create a new updated list.
@= common items in this package...listed in nearly all versions of the extreme builds...
(****) = Part number is wrong and I cant find the right number for it..
Some items are relisted from the old list as well...(the numbers still work...)
( PARTS #'S CAME FROM HERE-> http://parts.nalleygmc.com/ )
XTREME BODY CODES - (CHEVROLET X88, EXTREME PKG V4A)
Xtreme Part Numbers: Stepside Bed
15034713 Xtreme Extended Cab Left Skirt
15034714 Xtreme Extended Cab Right Skirt
15034715 Xtreme Front Left Fender Flare
15034716 Xtreme Front Right Fender Flare
15034717 Xtreme Bed Flare***
15034721 Xtreme Bed Front Left Skirt
15034722 Xtreme Bed Front Right Skirt
15034723 Xtreme Air Dam
15034727 Xtreme Bed Rear Left Skirt
15034728 Xtreme Bed Rear Right Skirt
15034744 Xtreme Filler Plate
15034747 Xtreme Fog Lamp Connector
5977934 Xtreme Fog Lamp
Xtreme Fleetside:
15034717 Fleetside Flare Left Side
15034718 Fleetside Flare Right Side
15034719 Bed Flare Right Side
15034720 Bed Flare Left Side
15034727 Bed Skirt Rear Right
15034728 Bed Skirt Rear Left
Cab Skirts:
15034750 Standard Cab Skirt Retainer
Bed Skirts/Steps:
15034752 Front Bed Skirt Retainer
15036164 Rear Skirt Retainer (Fleetside)
15036166 Right Rear Skirt Bracket (Fleetside)
15036165 Left Rear Skirt Bracket (Fleetside)
Blazer Xtreme parts list
15056105 (1) sideskirt
15056106 (1) sideskirt
15056109 (1) bumper end
15056108 (1) bumper end
15034723 (1) airdam
15034715 (1) flare frt
15034716 (1) flare frt
15056103 (1) flare
15056104 (1) flare
15056469 (1) hardware
15056107 (1) hardware
15993201 (20) hardware (SideSkirts)
15613054 (4) hardware
15053247 (3) Xtreme emblems
15036162 (1) hardware
15036163 (1) hardware
15037586 (1) airdam bracket
15037587 (1) airdam bracket
Zq8 Center Caps
# 15094627 gold/gold bowtie 99-03 $124.34
# 15092731 silver/silver bowtie 99-03 $124.34
# 15035067 silver/gold bowtie 99-01 $66.80
GM Roll Pan
# 15958890 REAR FILLER PAN
Bumper / License Lights
#918399 lamp housing
#16503699 retaining clip
#12083460 socket
#4830147 license protector
EXTREME FOG LAMPS AND CONNECTORS
#15034747 Fog Lamp Harness Req: 02 For: Chevy Xtreme Pkg(V4A) $153.11
#12450143 Fog Lamp Bulb(ACDelco #880L)(Longer Life Bulb) Req: 02 For: Fleetside,Chevy Xtreme $25.58
#16530308 Fog Lamp Housing $141.45
#16511383 Foglamp Adjuster Bolt Req: 01 For: Chevy Xtreme Pkg(V4A) $4.25
#12337881 Foglamp Adjuster Spring. Req: 01 For: Fleetside, Stepside,Chevy Xtreme Pkg(V4A) $2.82
#10030367 Foglamp Adjuster - Body Clip Adjuster Req: 01 For: Fleetside,Stepside,Chevy Xtreme Pkg(V4A) $4.46
FRONT COIL SPRING
# 15654770 - 2.2l 4cyl QTY:1 FRT COIL SPRING(wrong #)(****)
# 15654771 - 4.3l 6cyl QTY:1 FRT COIL SPRING(wrong #)(****)
EXTREME SIDES AND BEDS
Ext Cab - Fleetside Bed - XTREME - SIDES
@#15053247 Emblem (Bowtie Xtreme) Reg: 02 $120.77
@#15678961 Emblem (Ls) Reg: 02 $10.97
#15044539 Roof Drip Molding Req: 01 LH For: Ext Cab $31.05
#15044540 Roof Drip Molding Req: 01Rh For: Ext Cab $41.46
#15197641 Roof Drip Molding Req: 01Lh For: Ext Cab Cargo/Seat Access Door(E24) (1996-1998) (1996 - 1997) $28.59
@#15034752 Rocker Panel Molding Retainer Req: 02 For: Ext Cab - (Short)Stepside,Fleetside, Xtreme Pkg(V4A) $48.59
#15034751 Rocker Panel Molding Retainer Req: 02 For: Ext Cab - (Long)Stepside,Fleetside, Xtreme Pkg(V4A) $69.17
@#15003947 Front Flare(Gray) - LH Req: 01Lh For: (X88),High Wider Pkg Zr2,Solid Paint Combo $236.35
@#15003948 Front Flare(Gray) - RH Req: 01Rh For: (X88),High Wider Pkg Zr2,Solid Paint Combo $236.35
@#15034715 Front Flare(Paint To Match) - LH Req: 01 For: Stepside,Fleetside, Xtreme Pkg(V4A) $462.69
@#15034716 Front Flare(Paint To Match) - RH Req: 01 For: Stepside,Fleetside, Xtreme Pkg(V4A) $444.57
@#11504736 Bolt Screw $4.25
@#15993201 Rivet Retainer Req: 22 $2.89
#15034713 Rocker Panel Frt Molding (Paint To Match) - LH Under Door Req: 01Lh For: Ext Cab Only - Stepside,Fleetside, Xtreme Pkg(V4A) $453.56
#15034714 Rocker Panel Frt(Paint To Match) - RH Req: 01 Next To Door Molding For: Stepside,Fleetside, Xtreme Pkg(V4A) $452.87
@#15034721 Rocker Panel Rr(Paint To Match) - LH Req: 01 For: Stepside,Fleetside, Xtreme Pkg(V4A) $191.44
@#15034722 Rocker Panel Rr(Paint To Match) - RH Req: 01 For: Stepside,Fleetside, Xtreme Pkg(V4A) $194.50
#15036166 Bracket To Hang XFX Bed Molding Req: 01 RH For: Fleetside, Xtreme Pkg(V4A) $35.47
@#11609411 Bolt; Nut $0.55
#20733729 Washer. Bumper/Fascia. $2.39
#15036164 Retainer Qtr Panel Lower Molding Req: 02 For: Fleetside, Xtreme Pkg(V4A) $62.60
@#15034727 Molding Lwr Bed Rear(Paint To Match) - LH Req: 01 Fleetside $370.48
@#15034728 Molding Lwr Bed Rear(Paint To Match) - RH Req: 01 Fleetside $399.43
@#15126056 Emblem - "Chevrolet" $51.92
@#15076350 LABEL "DO NOT TOW" Req: 01 $19.02
Ext Cab - Stepside bed - XTREME - SIDES
@#15053247 PLATE (BOWTIE XTREME)Reg: 02 $120.77
@#15678961 Emblem (LS) Reg: 02 $10.97
#15044537 Roof Drip Molding Req: 01 LH For: Stnd Cab $29.25
#15044538 Roof Drip Molding Req: 01 RH For: Stnd Cab $30.63
#15718382 Lower Bed Skirt - RH Req: 01 $30.23
#15712063 Lower Bed Skirt - LH Req: 01 $36.42
#15712064 MOLDING Outer Side Decore RH Req: 01 $40.98
#15712059 MOLDING Outer Side Decore Fuel Door & Body Side LH Req: 01 $12.76
#15712060 MOLDING BODY SI LWR RR - RH Req: 01 $11.37
#15712057 MOLDING FRT S/D LWR(DLR MAY NEED TO RE-USE BOWTIE S10 EMBLEM OR ORDER PN:15733585) - LH Req: 01 $132.34
#15712058 MOLDING FRT S/D LWR(DLR MAY NEED TO RE-USE BOWTIE S10 EMBLEM OR ORDER PN:15733585) - RH Req: 01 $128.87
@#15003947 Front Flare(GRAY) - LH Req: 01LH For: (X88),High Wider Pkg Zr2,Solid Paint Combo $236.35
@#15003948 Front Flare(GRAY) - RH Req: 01RH For: (X88),High Wider Pkg Zr2,Solid Paint Combo $236.35
@#15034715 Front Flare(PAINT TO MATCH) - LH Req: 01 For: Stepside,Fleetside, Xtreme Pkg(V4A) $462.69
@#15034716 Front Flare(PAINT TO MATCH) - RH Req: 01 For: Stepside,Fleetside, Xtreme Pkg(V4A) $444.57
@#11504736 BOLT SCREW $4.25
@#15034752 Rocker Panel Molding Retainer Req: 02 For: Stepside,Fleetside, Xtreme Pkg(V4A) $48.59
@#15993201 Retainer. RIVET Req: 18 $2.89
@#15034721 Rocker Panel(PAINT TO MATCH) - LH Req: 01For: Stepside,Fleetside, Xtreme Pkg(V4A) $191.44
@#15034722 Rocker Panel(PAINT TO MATCH) - RH Req: 01For: Stepside,Fleetside, Xtreme Pkg(V4A) $194.50
#15034729 EXTENSION. Rear Bumper Step PAD(PAINT TO MATCH) - LH Req: 01 For: STEPSIDE $419.74
#15034730 EXTENSION. Rear Bumper Step PAD(PAINT TO MATCH) - RH Req: 01 For: STEPSIDE $406.26
#15733585 Emblem (CHEVY BOWTIE W/S10) Req: 02 For: Body Side Molding,CHEVROLET(X88),CONVENIENCE PKG #3(YC3) $18.77
@#15076350 LABEL - "DO NOT TOW" Req: 01 $19.02
Standard Cab Sides - XTREME - SIDES
@#15034727 MOLDING LWR BED REAR(PAINT TO MATCH) - LH Req: 01 Fleetside $370.48
@#15034728 MOLDING LWR BED REAR(PAINT TO MATCH) - RH Req: 01 Fleetside $399.43
#15034750 Retainer. Rocker Panel Front Molding Support Fits: Stndrd Cab Only - Req: 02 $101.27
@#15034721 Rocker Panel RR(PAINT TO MATCH) - LH Req: 01LH For: Stepside,Fleetside, Xtreme Pkg(V4A) $191.44
@#15034722 Rocker Panel RR(PAINT TO MATCH) - RH Req: 01RH For: Stepside,Fleetside, Xtreme Pkg(V4A) $194.50
@#11609411 NUT $0.55
#20733729 WASHER. Bumper/Fascia. $2.39
Standard Cab - Stepside bed - XTREME - SIDES
FRONT BUMPER - ALL SERIES
#15007660 Front Bumper (GRAY)(PAINT TO MATCH) Req: 01(DRILL AS REQUIRED FOR ZR2). Req: 01 $295.34
#15094048 Front Bumper (CHROME)(W/RUB STRIP HOLES). Req: 01 For: CHEVROLET(X88),(EXC CONVENIENCE PKG #3(YC3) $261.92
#15672093 Bumper Mounting Clip. Req: 08 $1.27ea
#11516328 Bumper Mounting Bolt. Req: 08 $1.61ea
#11516328 Bumper Mounting Side Brace Bolt. Req: 08 $1.61ea
#15716713 Bumper Mounting Side Brace LH Req: 01 For: ST1 CHEVROLET(X88) $26.31
#15716714 Bumper Mounting Side Brace RH Req: 01 For: ST1 CHEVROLET(X88) $26.31
#11516328 Lower Bumper Brace Mounting Bolt. Req: 08 $1.61
@#11516993 Body Retainer Clip Req: 14 $0.76
#15036162 LHD Airdam Retainer Bracket $66.49
#15036163 RHD Airdam Retainer Bracket $59.73
#11609411 Airdam Retainer Bracket Bolt Req: 04 $0.55
#15037586 Airdam Lower Support Bracket. RHD Req: 01 $42.80
#15037587 Airdam Lower Support Bracket. LHD Req: 01 $55.64
#11519444 Plastic Retainer Bolt $1.98
@#15993201 Plastic Retainer Rivet $2.89
#15034723 Front Airdam (PAINT TO MATCH)(INCLS DEFLECTOR). Req: 01 For: CHEVY XTREME PKG(V4A) $469.22
#15034744 Xtreme License Plate (PAINT TO MATCH). Req: 01 For: CHEVY XTREME PKG(V4A) $176.61
#10215009 Spacer Req: 02 For: CHEVY XTREME PKG(V4A) $4.28
#11609411 License Plate Bracket Nut Req: 04 $0.55
#15732300 License Plate Bracket Bolt (M6X1X25MM W/WASH) Req: 04 For: FRT LIC PLT MTG PKG(VK3),CHEVY XTREME PKG(V4A) $5.08
EXTREME WHEELS
#15094221 Extreme Wheel 16X8 Frt(Gold). Req: 02 For: S1 Body Emb(B94),Al Whl(N96),Chevy Xtreme Pkg(V4A) $599.29
#15731941 Wheel Center Cap (Gray Plastic W/Gold Bowtie). Req: 04 For: S1 Painted Al Whl(N60),Chevrolet(X88) 84.19
#15092731 Wheel Center Cap (Silver)(Silver W/Gold Chevy Bowtie On Black Background) Req: 04For: Chevy Xtreme Pkg(V4A) $203.39
#15094627 Wheel Center Cap (Gold)(Gold W/Gold Chevy Bow Tie On Black Background) Req: 04 For: Chevy Xtreme Pkg(V4A) $169.52
#15661026 Wheel Center Cap (Gold Chevy "Bowtie" On Black Background). Req: 04 For: S1 Steel Whl(Ph1),Chevrolet(X88) $78.81
#15194360 Extreme Wheel Center Cap Req: 04 For: St1 Styled Al Whl(Pw7) $91.54
#15661036 Lug Nut Cover (M24 X 2) Req: 20 For: S1 Painted Al Whl(N60),Chevrolet(X88) $3.53
#10028615 Lug Nut Cover (M12X1.5 W/M24X2.0) Req: 20
Wheel Fitment/Applications
Chevrolet Blazer 2WD 1999, 2000, 2001, 2002, 2003
Chevrolet Blazer 2WD Trailblazer 1999, 2000, 2001, 2002, 2003
Chevrolet S10 2WD Pickup 1999, 2000, 2001, 2002, 2003
Gmc Jimmy 2WD 1999, 2000, 2001, 2002, 2003
Gmc Jimmy 2WD Envoy 1999, 2000, 2001, 2002, 2003
Gmc Sonoma 2WD 1999, 2000, 2001, 2002, 2003
Blazer Xtreme - Sides
#15724145 Windshield Molding LH Req: 01 For: St1 (Exc European Wdo Glazing(A26)(Export) $59.66
#15724146 Windshield Molding RH Req: 01 For: St1 (Exc European Wdo Glazing(A26)(Export) $59.66
#15994411 Windshield Molding LH Req: 01 For: St1 European Wdo Glazing(A26)(Export) $39.88
#15994412 Windshield Molding RH Req: 01 For: St1 European Wdo Glazing(A26)(Export) $39.73
#15732581 Windshield Molding Bolt/Screw Req: 08 $4.49
#15726940 Windshield Upper Molding $12.92
#15095245 Windshield Decal,W/S Na(Gold)(Xtreme) Req: 01 For: S1(03-16-53) Acnt Strpe(D98),Chevy Xtreme Pkg(V4A),(54A) (2002-2003) (2002 - 2003). $63.57
#15771157 Windshield Decal,W/S Na(Yellow)(Xtreme) Req: 01 For: S1(03-16-53) Acnt Strpe(D98),Chevy Xtreme Pkg(V4A),(59A) (2001-2002) (2001 - 2002). For: S1(03-16-53) A... Show More $63.56
#15111819 Side Window Roof Drip Molding RF PNL JT FIN(Plastic) - LH Req: 01 For: St1(16) $20.04
#15704032 Side Window Roof Drip Molding RF PNL JT FIN(Aluminum) - RH Req: 01 For: St1(16) $24.17
#15056103 Rear Wheelwell Flare (Paint To Match) - LH Req: 01 For: S1(16) Chevy Xtreme Pkg(V4A) $446.66
#15159525 Rear Wheelwell Flare (Gray)(Paint To Match) - LH Req: 01 For: St1(16) Chevrolet(X88),High Wider Pkg(Zr2),Solid Paint Combo(Zy1) $389.46
#15159526 Rear Wheelwell Flare (Gray)(Paint To Match) - RH Req: 01 For: S1(16) Chevrolet(X88),High Wider Pkg(Zr2),Solid Paint Combo(Zy1) $417.03
#15613054 Rear Wheelwell Flare Screws (4.8 X 1.59 X 20.0 Mm)(08.133). Req: 10For: S1(16) Chevy Xtreme Pkg(V4A) $7.86
#15056105 Rocker Panel Side Skirt (Paint To Match) - LH Req: 01 For: S1(16) Chevy Xtreme Pkg(V4A) $270.91
#20830823 End Gate And Rear Door Decoration - Decal(Gold)(Bowtie W/Adhesive Tape). Req: 01For: S1(16) Chevy Xtreme Pkg(V4A) $51.24
@#15993201 Plastic Rivit Retainer $2.89
@#11516993 Clip; Nut; Retainer Nut $0.76
#15613054 Front Wheelwell Flare Screws (4.8 X 1.59 X 20.0 Mm)(08.133). Req: 14 For: S1(16) Chevy Xtreme Pkg(V4A) $7.86
@#15034715 Front Wheelwell Flare (Paint To Match) - LH Req: 01 For: S1(16) Chevy Xtreme Pkg(V4A) $474.25
@#15034716 Front Wheelwell Flare (Paint To Match) - RH Req: 01 For: S1(16) Chevy Xtreme Pkg(V4A) $455.68
@#15053247 Extreme Side-Body Emblem (Charcoal)(Bowtie Xtreme) Req: 02 For: S1(16) Chevy Xtreme Pkg(V4A) $123.78
Enjoy...
I worked months on this..., with my local dealer to verify these numbers and the cost. Your cost may be different.
l8taz,
Allen :cool::eek::cool::D
Premium Member
nice writeup. i lold at the do not tow label being $19.
i may look into the price of the rollpan at my local dealer.
Registered Hoosier
How can I get parts off of your list
Sent from my iPhone using Tapatalk
This list is over 4 yrs old. Pick out the numbers you want and check with your dealer, or with an online GM parts dealer. I'm betting a lot of these parts are no longer available.
Status
