i am swaping a auto of a t-5 and i have a parts truck with every thing i need but i do not know if the wiring will work i know how to change clutch pedal and the tranny. so do i need to change wiring harness?
A4, A5, A6, A8 ASE Cert
You also should be worried about a non-existing pilot hole on the crank shaft. the pilot hole is for the front end of the Manual trans. Autos never needed it. so you may not even do it because of the crankshaft.
the youngest has been
the hole will be there
