My temperature gauge went out in my 2.8 4x4 2.8 went out after i changed my fuel pump.. i disconnected a pink and black wire, but reconnected it if that has anything to do with it. I cant find a good diagram to help me, so i hope you guys can. It works 15% of the time but not really any more... it usually goes out when the temp is up. The fuel gauge also doesnt work since i did the pump, if that helps at all, but i think that might be due to a mixed up wiring when i was testing the fuel pump and something threw some smoke.... but anyway.. temp gauge, whats wrong, how do i test it and fix it? THanks
