Appreciate it. I hope you all got something from it all.
Appreciate it. I hope you all got something from it all.Nick, once again I will say it, YOU'RE A GENIUS! Your work is amazing and thanks a lot for this thread and any help you have given out over the years. I wish I could get my shit straight so I can get back to doing my fiberglass work. Thanks again man. Hopefully I can get back on the grind and get a new project. I just need to get my mind right.
but it's not....what's so hard to understand......you MUST have fiberglass to fiberglass something.period:haha:i c it as glassin and i c it as the wrong way to glass. i use the fiberglass cloth and shit not fabric.
u kno wat i mean thobut it's not....what's so hard to understand......you MUST have fiberglass to fiberglass something.period:haha:
it's like ''fiberglass resin''........there is no fiberglass in resin
it's polyester resin
no...i don't really know what you mean?i c it as glassin and i c it as the wrong way to glass. i use the fiberglass cloth and shit not fabric.
batch dried slow but still dryed i could have used a lil more hardner thono...the best way to start is not diving headfirst in......start small so you get a feel for it.....you already wasted a cup of resin because you don't know what you are doing......i might add that you are now going to strip it back off
if you had spent more time researching you might have read where me and nick both state that you need to start small or you will overwhelm yourself and get frustrated
and if you don't want to hear that you are doing it wrong then you might want to stop posting right now because i can tell right now you are going to hear that alot because you can't even read the mixing instructions on the can that states how many drops of hardner per oz. of resin are required
no i measured in spoons full i explaind what i did wrong. but ether way i was still off by about 5-10 your right. whats the average wait time for a normal batch befor you do a second coat tho? and 3rd? also is it ok to use like screen door metal screen for a more solid structer with the woven glass on both sides ? i was thinking for my dash the glass should hols if i get 4 layers down but i want it to support some 10 lbs max do you think the skreen would just be pointless?ok...you said a measuring cup which i automatically assumed it was 8 ounces
granted you should use 7-12 drops per ounce(depending on temp) then i thought you came up like 50+ drops shy.....
Yes and No. It depends on what method you're taking. If you are doing a wet layup where mutiple layers are going on one after the other without curing, then you have the added benefit of a chemical bond once all layers cure as one. However, if you allow it to cure more than a couple hours (depending on environmental temps and the # of drops of hardener added), then you'll loose the option for chemical bonding anyway which would require a quick scuff grinding before moving forward with the next layer. Its the state of the cure that depicts the type of bond.............which could be a result in minutes, or hours.overnight is too long without grinding, you lose the chemical bond
ok so for my second layer i just scuffed it up and put more on but im new to it so...overnight is too long without grinding, you lose the chemical bond
Thanks for whoring your pictures of what looks like simply overkill just to be cool smart guy and answer a question asked damn near a freak'n year ago. You now have all the cool points status. How many pairs of eyes do you have? I bet its hard to watch 50 tvs at once. Ever heard of "Less is more"? Nice job but save the show boating for another thread.MDF stands for Medium Density Fiberboard
Glassing is time consuming but if you do it right it looks like this![]()
Wow someone is butthurt Because you could never pull off anything close to what i do every day. I know your pissed but it shows why. When you start a thread on how build custom panels you should first build something that actually looks nice instead of that piece of crap you call a dash.Thanks for whoring your pictures of what looks like simply overkill just to be cool smart guy and answer a question asked damn near a freak'n year ago. You now have all the cool points status. How many pairs of eyes do you have? I bet its hard to watch 50 tvs at once. Ever heard of "Less is more"? Nice job but save the show boating for another thread.
