I don't know what yr your ride is, but if it's a 1st Gen or early
2nd Gens, and it has the orig ign module inside the dist, there's
a real good chance the module is getting a heat sink, The
dielectric grease that isolates the ign module form the dist
mount base will dry up after a few yrs and allow a heat sink
into the ign module..You can ck it by disconnectiong the NEG
side of the battery, pull the cap, pull the two screws that hold
the ign module out and remove the module..
Look at the grease on the module's base and the dist base. If
it's dry, hard and yellow or even looks a bit nasty, it's no good.
Most times it's cheaper to just repalce the module, Once they get
a heat sink you'll never know when they will crap..The
new module comes with a small tube of dielectric grease.
You want to make sure you clean the dist base REAL good
and smear the grease COMPLETETLY over the dist ign module mounting base.
The more the better..Put it all back together and see what happens...
The module is critical for fuel delivery and oil
press voltage to the ECM. If the ECM doesn't see a good rpm
signal from the module, it will not fire. A heat sink can cause this.
Running the engine until it gets warmed up will allow a heat sink
from the dist's mount base for the ign module to the module's
base, IF the grease and ign are old resulting in a hard or no
start after running for a while...There may be something else
wrong but this is what I have run into more times than not..
