1 - 20 of 34 Posts
Teh S10Forum Hawk
well after about a month of trying to figure out how to do it, i finally got it worked, so i thought i'd like to pass the advice on to you guys.....
first download a program called fairuse4wm
http://jamesholden.net/fairuse4wm-download/
then extract the files and see if it works.. if it says cannot find keys or whatever then go to this site
http://forum.doom9.org/showthread.php?t=127943
and download the patch.... run the patch, hit start and it should find 1 key (assuming you have a current license on at least one DRM copyrighted song) and then just exit the program.
go to back to the fairuse program that didnt work.. now it will work..... and everything from here is self-explanatory, create an output folder for your music and add songs for the DRM to be stripped..
college students be sure to make an account over at www.ruckus.com its the best music D/ling site i hvae used, i had about 25,000 songs from it and they were all the DRM copyrighted....
microsoft must be shittin their pants right now.....
The Beast
Holy Shit. You are a god amongst mere mortals. Thank you so much dude.
Teh S10Forum Hawk
Discussion Starter #12
i did this for music.... my zune is almost 30 gigs full now, the other day it was at 2gb. BAHAHAHA
Why did like nobody care about this shit when VHS was around? I remember back in the day recording rented movies like a mofo. The didn't bitch back then.
They actually did. They started putting some kinda magnetic type thing on the tapes, it interfered with the signal running through the cables. the way around it was to use the A/V wires instead of the (coxial?) cables, which ended that right away.
Teh S10Forum Hawk
Discussion Starter #18
k i pm'd you... but just listen here
get songs from ruckus.
download the fairuse4wm file... follow the steps..
if you get an error that it cant find a "key"
then download that 2nd link in my first post.... run that program and it should find a valid key on your computer
now go back to the fairuse4wm program and it should be a blank screen where at the bottom you will see an "add file button"
from here its self explanatory.... add the file, select what folder you want it go in.. then hit submit or w/e the button is..
anymore q's just let me know, let me know where your stuck at or somethin
1 - 20 of 34 Posts
