Tailgate won't release from dash switch. I remove and checked tailgate solenoid and it works. I then removed the dash switch and and shorted the wire harness and just got sparks. So I guess there is a problem from the dash harness and the solenoid.
Any suggestions out there ???. I did order another switch from the dealer.
It should work off a relay. I think its under the dash with the circuit breakers and chime modules.
Found tailgate problem
Had someone help me and by shorting out the switch harness, found that the motor won't pull the latch open. Motor works but have the power. I guess I will go to the dealer in the morning.
