ya my tail gate seems loose n goes side to side over 1/4 n wobbles in n out", how can i get it to stop? just add washers between the the bolts n bracket thing to shim it off?? all the rubbers seem to be on there
Just more shitty GM engineering. The edges of my bed are all chipped up because of the same problem. The slack is built in there so you can push the tail gate to one side and just lift up for removal.
My old Chevy truck just has bolts. It was a bitch to remove for sandblasting, but once in 25 years is no big deal.
ok problem solved 4 the side to side movement, added washers inside, as for the back n forth, im not sure, i might just make some rubber pads inside n hope it dont stick out passed the box sides any
