Well heres the deal. My truck is a 95 s10 with a 5.3 and a harness made by cpw. The truck didnt originally come with a tach cluster and i drove it without one for about 2 years but last weekend I found a tach cluster in a 96 blazer and threw it in. It seemed to work fine, the idle looked a little low to me (500rpm) I had no idea of that was normal or not for a v8 because most engines I see idle around 900 to 1k but when I rev mine up to 1k it just sounds like its spinning too fast for not much rpm. Also im pretty sure I had my shift points set to 5400 I mayb be wrong, I know its always shifted earlier than I like but the tach says it shifts at about 3900-4k at wot and for some reason the engine sounds like its working way harder than what the tach says I mean I have a really loud exhaust so that may be throwing me off too. Could this be a problem form having a v6 tach on a v8? Doesnt it usually read higher when you do that? Im not saying the tach is wrong im just wondering if theres a way I can check it to be sure. Thanks alot
