Alright I Just bought 2 t5 trans ones from a 2.8 ones a non world class and the others a world class. I have a 350 I’m swapping I’ve been told t5 will bolt up to the 350 is this still true with these trans?
time to get cereal
No they have a different bellhousing pattern. The world class also has a Ford pattern on the case.
Alright since they won’t work do they make bell housing adapters to bolt the trans to a 350 since the t5 bell housings are removable
time to get cereal
The interwebz is your friend. This site should help you see the light... It's not impossible, but you're better off starting with a stronger transmission in the first place.
That site says 93 and earlier are Muncie pattern cases, but other sources of info say 93 was WC, and WC transmissions all had Ford pattern cases. If both of your transmissions have the same case pattern, that would make using the WC easier, as you can find a Camaro bellhousing to put on it. As you can see though, the input shaft will have to be swapped out as well.
