I have 94 2.2 and the transmission is leaking / seeping out from between he tailshaft housing and the trans. .is there any type of gasket or sealant between those two surfaces. Is it an easy fix? Trans is already out of the truck.( Had to replace the bell housing for the second time. Any advice or help would be greatly appreciated. Thank You!
time to get cereal
Do you have all of the bracing installed? Missing bracing is the only thing I can think of that would cause repeat bellhousing cracks. Should be a brace on each side of the motor going to the bottom of the bellhousing and then 2 braces on each side of the transmission.
Wood Bumper Automotive exterior Gas Electrical wiring
As for the tailshaft seal, I'll have to look at the service manual. I haven't ripped one apart yet.
