Which Suspension Setup is best for a 3/4?
  • 2" spindles, 1" springs w/ 3" leaves,1" blocks
    Votes: 16 80.0%
  • 3" coils and 4" blocks
    Votes: 1 5.0%
  • 3" lower control arms w/ 3" leaves, 1" blocks
    Votes: 0 0.0%
  • none of the above (Please reply w/ your advice)
    Votes: 3 15.0%
1 - 11 of 11 Posts
Proud to be a Cop!!!
I am going to lower my truck really soon. I have decided though, that when I lower it I am going all out sport suspension (handling purposes). I think I am going to go 3/4 Beltech (2" spindles, 1" coils)(3"drop leafs, 1" angled block) Also I want to put sway bars and poly bushings. For shocks, I am going to use Toxic's 10-stage. Any Suggestions?
Also, does anybody know where I can get good quality sway bars and maybe a strut tower?
if u want handling your probably gonna want to go with the smallest block possible, because the bigger the block the more wheel hop it cuses. so something like a 3" leaf and 1" block in the rear and sindles and 1" springs up front. as for the sway bars u shoudl just get some stock ZQ8's cause they are pretty damn big 1 and 1/4" up front and 7/8" out back im pretty sure. toxics are hella stiff if u dont mind it then go for it.
I say start with the spindle and drop leaf platform and work your way down. If I had to do it again, I probably would have gone leafs first instead of the 4" blocks.
Jay
well it all depends on how much you plan on spending
3" coils and 4" block would be cheapest
but i think that the best way to go would be 1" coils, 2" spindals, 3" leaves and 1" block
as far as shocks i use either belltech's nitro active about $45each(not belltech nitro drops, about $25 each) or doestch tech about $40 each....the belltech nitro actives and the doestch tech are about the same in quality.
I wouldn't go with Toxic's, just installed some today, ride like crap, unless you don't mind. My other buddy has Nitro drops in his xtreme and they're not so bad.
1 - 11 of 11 Posts
