Would completely shot upper control arm bushings cause wondering and steering play. I have a lot of that plus the idler moves a decent bit. Just trying to figure if its gearbox play or not. 1997 s10 208k miles and 4x4.
Yes this is very possible.Would completely shot upper control arm bushings cause wondering and steering play. I have a lot of that plus the idler moves a decent bit. Just trying to figure if its gearbox play or not. 1997 s10 208k miles and 4x4.
Not trying to be critical, but merely making an observation, beings (depending how you look at it) "So far, so good."This was never meant to be a tutorial on doing an alignment. That is what professionals with proper equipment are for. As I said before, anyone claiming that you can properly align a vehicle in a driveway and get decent tire wear over the long term is mistaken. Rather, tutorials that show you that kind of information should be used as a temporary adjustment to get you to a shop with proper tools and equipment.
Tire pressure effects the specs of a given vehicle's alignment depending on the difference between each wheel from side to side. (IE- Driver's Front is at 35 psi vs Passenger Front being at 20psi would result in a different camber reading, and in some cases toe, than if they were even.)mojarraman said:HOW DOES TIRE PRESSURE AFFECT CAMBER? To what extent? How many degrees? Then what about toe?
HOW DOES TIRE WEAR AFFECT CAMBER? To what extent? How many degrees? Toe?
Correct , I used the wrong word which can be misleading to someone who doesn't know the difference. If not abused or other issues arise with bushings and the like, an alignment will stay true until outside forces (collisions our failing parts/bushings) come into play.mojarraman said:Before asking/answering related question, this can be misleading (to those unaquainted): "Yes, with age and general wear and tear, the settings will change. It's from the bushings getting weak."
NO, there aren't any "settings" that change, not in the mind of the alignment tech.
Settings get set - and that's that. "Settings" are mechanical adjustments in nuts/bolts/shims/lobes ...
No. A driveway alignment is not meant to be a final solution. Using a tape measure will get you close, but not where it should be in order to assure proper tire wear for the life of the tires (Tread wear warranties are now upwards of 100,000 miles on some models of tires). Even a computerized alignment can't guarantee proper wear over that length of time with out routine checks and adjustments if needed. Many thing effect tire wear. Improper tire pressure being the leading cause next to improper alignment. Proper tire pressure isn't what your door placard or tire sidewall states either. Proper tire pressure is the pressure your tires have the optimal contact patch given your vehicle weight and current tire size.mojarraman said:When is mentioned, "Driveway alignments are meant for simply getting the vehicle to a shop. People that say they work are looking at the short term," maybe it should be understood (or perhaps, perhaps) better yet expressly stated:
"If your last alignment was good, it's NOT JUST 'from the bushings getting weak' that caster/camber/toe is outside (FSM) specifications. Worn shocks/struts is perhaps a GREATER reason (as is tire wear and/or pressure). Tie rod ends might contribute, but steering wobble or play will likely be evident as well."
If you replace a part like a control arm, strut, tie rod, etc. you need an alignment. Flat out. If a part is replaced, there was a reason for it. Parts don't wear out in just a day or even a week. If you have a part that is worn out, it has already thrown your specs out of acceptable tolerance, which will not necessarily be the same if you just slap a new part in there. Even counting threads when replacing a tie rod or tie rod end will not get you back to "acceptable specs". Control arms are the same way. You can't guarantee that a control arm from one manufacturer is 100% perfect in their production of a part, even if they say "OEM quality or better".mojarraman said:Maybe should also be stated (as this is confusing to the J.Q. public):
"If your last alignment was right/correct, and barring a collision, or bad motor mount, then *replacing* old/worn suspension components (JUST the LCA's?) ought to return (closely) the alignment, maybe even to within acceptable specs."
Also, "if steering linkages (such as BOTH inner and outer tie rods) are replaced, then a toe (and JUST a toe) alignment may well be required to return specs ... However, if just a set of outer tie rod ends is replaced - meaning no inners - and done properly - then the toe should quite possibly stay quite close to specification, i.e., provided other suspension components are good." Then lastly: "many rack & pinion vehicles (w/ no upper a-arm) will not require any caster/camber alignment whatsoever - simply replace the LCA (bushings/ball joints) and strut assemblies and little linkages then it's good-to-go."
Naturally all this assumes doing things in pairs/quads - as should normally/always be done.
This would fall under "driveway alignments". That is unless you can 100% guarantee that the platform the alignment was performed (I assume you're thinking a car port slab) is perfectly level on both axis. Even then I would still take it to a reputable shop to be sure (this is where researching the shops and meeting the technicians comes into play).mojarraman said:Of course, FSM specification for alignment are started as "prefered" specifications, and who is to say something such as Trackace Laser Wheel Alignment Gauge https://alignyourcar.com/
would not yield "VERY decent tire wear over the long term?"
Of course, all of this suggests something important to any alignment: a well established center line. BUT YOUR LAST ALIGNMENT (with no bent/bad parts) already GAVE YOU THAT, esp. w/ rack & pinion, and so I guees it might be BETTER said:
On a lot of cars, merely requiring a tweak in the toe (and not a true, full-fledged RE-alignment), which is often the case with "R&I struts & [loaded] lower control arms" [inc. of course bushings/ball joints] then something like the Trackace Laser Wheel Alignment Gauge might be ABSOLUTELY GOLDEN?
While I appreciate your drive and will to learn about these things, a lot of what you said was misinformation resulting from theoretical education (lots of books and limited real world experience). As I said in my original post, I'm by no means 100% perfect nor do I know everything there is or ever will be to know about suspension and alignments. Just last week I learned something new. However, my 12 years of hands on experience in a shop dealing with thousands (not exaggerating) of vehicles over the coarse of that time, has shown me that Chilton/Haynes/FSM while very good starting points for understanding how these things work and what effects different things at different times are limited in most areas.mojarraman said:It'd help to say what I put at the begining:
I'm no mechanic, and would never pretend to be one, let alone an alignment technition. So maybe everything I've written/suggested/thought/believed and/or read on the subject is utterly spurious dog doodoo. But what I HAVE done - after digging into the front suspension (not steering) of a grand total of about 3 cars/trucks - I know that's a SMALL number - is (also) carefully read & digest from Chilton/Haynes/FSM/Internet over the course of a couple-odd-weekends (several-dozen-hours reading) and consolodated into writing what working on the 3 cars/truck has caused me to THINK.
It's up to others (if they are so inclined) with lots of experience in all these facets to help discern where/when/if (in all practical, hands-on and driving) experience proves any/all/some of this to be partly/totally true/false. Just kicking it out there ... tending to THINK it's at least maybe 92.5% correct the way I've expressed/asked it - and have looked at Chilton/Haynes/FSM to TRY to see where I might be wrong. Truth be told, generally hoping where I've made any mistake(s) WILL get pointed out. Nothing wrong with expressing things wrong except the failure to admit (and learn from) it.
While the difference between 0.0° and 0.1° seams very small (and it is), there is a BIG difference when you are talking about total toe, much less individual toe. To put it into perspective, the machine I use at work reads 0.01° for both individual toe an total toe. That's 10 times more accurate. In terms of tire wear, which is most effected by total toe, that is the difference between a nice even wear pattern and this:mojarraman said:FWIW, the Trackace Laser Wheel Alignment Gauge https://alignyourcar.com/ $99
seems to give a (total) toe to within 0.2 degrees, although I can't see why it wouldn't yeild a (total) toe accurate to 0.1 degrees? The man who invented/sells the thing seems honest. And on a FWD, 0.0 or 0.1 negative front toe, what's the difference? That's not a smart-ass question, I honestly don't KNOW why 0.0 (total) is any better than a negative 0.1 (total) - or for that matter 0.1 (total) positive. For example RWD are 2.0 or 3.0 negative front toe if I'm not mistaken. Last question, I promise; what IF "you have a 4WD, but drive in 2WD 99% of the time? What then?" Should you toe it "like" a 2WD?
If a part is replaced, take it to be aligned. You can't garruantee it'll be right. You will burn off the tires. "OE quality or better" doesn't translate to "don't worry about aligning it, it's close enough".PS: it's worth mentioning the immediate point about "the well established center line" is well taken
PROVIDED one remembers it means in conjunction with an aproximately ZERO "total FWD toe to begin with" resulting from the last alignment.
Re-phrasing;
a DIY driveway alignment IS doggey doo doo bunk garbage IF both inner and outer tie rods are being replaced. And MAYBE (or realistically) it's bunk also if the UCA's need replaced.
But here's the kick; on a double wishbone the UCA (ball joint) is normally not load-bearing. It's generally kinda/sorta "along for the ride": so if ever there were a margin for error, replacing JUST the [loaded] LCA and skipping a "pro" alignment, it might get the 10K+ miles and still be relatively safe? Yet might burn tires some?? I hate to speculate on that, especially beings I'm seeing cars/trucks where ALL front suspension parts seem to go to pot all at once. It seems a dial indicator (or just old fashioned grab/wobble test) would rule in/out a "definite yes/no" and supercede speculation when human lives are at stake.
I said that because only the parts that are worn, damaged, or otherwise out of specification should be replaced. If a tie rod is the only bad part, you wouldn't replace everything or anything else for that matter."If you replace a part like a control arm, strut, tie rod, etc. you need an alignment. Flat out."
Is why I NEVER mentioned that. I spoke of replacing parts, worn parts, all worn parts, in groups, and I'm a bit surprised any conrary inference was made.
Let say a FWD car comes in for an alignment. I find a bad the rod end. The alignment heads are not hooked up until the part is replaced. I replace the part and perform the alignment setup procedure. I find the camber is out as well as the toe. I adjust everything I'm able to, including camber."If you have a part that is worn out, it has already thrown your specs out of acceptable tolerance, which will not necessarily be the same if you just slap a new part in there."
No. Rather, this is counter reasoning to a specious argument.
"slap a new part in there" is against the spirit of (and literal content of) most/all of what I'd suggested. It presumes a vagueness that wasn't intended. I'm not sure it adds, and perhaps obscures the paplpable truth about the case of FWD front toe-only cars. A front-toe car (and there are hundereds of thousands at least) suggests "only a LCA (no upper a-arm) car where the FSM (almost always) or at bare minimum FREQUENTLY states categoricaly w/r/t (front) alignment:
Step 1) Replace worn parts
Step 2) Adjust front toe. End of Story. There IS NO caster/camber recomended.
Yet "finding out camber" is something the very very typical aligment shop purports to do - at $79 to $89 per pop.Let say a FWD car comes in for an alignment. I find a bad the rod end. The alignment heads are not hooked up until the part is replaced. I replace the part and perform the alignment setup procedure. I find the camber is out as well as the toe. I adjust everything I'm able to, including camber.
Just because a vehicle tracks straight or drives normal doesn't mean the toe is within acceptable specs. I've driven thousands that drove just fine, yet needed adjustment on the front and rear toe. Some vehicles with struts have and elongated upper or lower (sometimes both) holes to allow for camber adjustment, some are simply a sleeve with a retainer bolt, and others are fixed hole sizes and locations and require a cam bolt kit to change camber." ... a lot of what you said was misinformation resulting from theoretical education (lots of books and limited real world experience).
I think maybe that's pushing things a bit. I can't yet be certain.
I did the Intrigue last week, and as far as you say about "holes not or maybe not lining up on struts to knuckle," that's just not the case there. Nor with the Crysler Sebring. No hole where the strut meets the knuckle (unless oblate from the factory) I've seen of the few I've fixed ever came close to anything but "real snug." Doesn't mean it COULDN'T happen, of course, just means the Crysler and GM I did fit glove tight or tighter. Tighter than a nun's tummy. Of course the SPRINGS might be different on my Moogs than AC/Delco...there's little (if any) doubt the camber IS affected - in an inconsequential way - 'less there's indication otherwise which there wasn't. Call me "Mr. Lucky" Lol!
For clarity or conviennce I counted threads, which wasn't really much ado, beings the "thread count" isn't the only way to assure retro-fit accuracy/closeness, and FOREWENT any alignment WHATSOEVER. Then, purely by happenstance I spse, THE CARS (OUR CARS, MY CAR) DRIVES AND TRACKS LIKE A DREAM.
That's one instance. I did the Crysler year-before-last, loaded LCA/struts, and while g/f drove it WAY more than I, she reported the car handled better than when she bought it - and 6months/7-8,000 miles the front tires showed little or no significant wear. Maybe I got lucky, pure luck, 2-times-in-a-row?
Often is suggested (RWD) 3.5 caster LEFT and 3.0 right or vice-versa (the minutae isn't ... microscopic?) Surely there's more explanation than mere tire rotation? You're suggesting a front positive 0.1 versus a 0.0 L compared to a 0.0 or say 0.1R spec is going to result in the abberant wear in the photo? Huh?
100,000 mile tires. That reads one-hundred-thousand. Many if not most of these DIY alignments are 10+ year-old cars to start. And so for <$100 I can go buy a 100,000mile tire?? In which zipcode?
A 50,000 mile tire, in reality, actual, true miles, maybe. Or else, tires have REALLY changed since I bought a pair Goodyear 60,000 about 5 years ago ...
Some sort of statistical, or even individual instance, might help bear things out.
A car tire in midwest winter, operates at how many degreesF? and in summer? and a 0.01 (on a car spec'd at 0.1 total front) decrepancy will change toe (and/or camber) HOW MUCH?
The toe and/or caster/camber will DOUBTLESS be affected by ambient tempF. And that effect is LESS than a 0.01 descrepancy from 0.0? These could be measurable, meaning the experiment could be performed but is meaningless unless some stats/specs/ and/or actual experimental (trial and error) data were purported; nonetheless you seem to be purporting that "tire alignment plain and simple" (and perhaps rotation and regularly monitered PSI) is going to yeild umpteen (100,000) jillion miles, WHEREAS some (relatively minute) discrepancy in toe is going to "burn through tires." Is that so?
I wasn't being pushy. I was trying to correct some misinformation you had as well as answer your questions. If you took it that way, then that's not really my concern. If anyone has come off as rude here, it's you just now. The thread was created to be a guide for basic alignment aspects and to show people what they can look for to same themselves a little money instead of being ripped off by shops that sell parts just to get money. Yes, I am a grease monkey and I do damn well for myself doing it too. I don't mind it one bit. :grin:mojarraman said:Actually, now I've read yer junk a little closer, you do seem pushy. I was dining politely w/ g/f quickly reviewing things and she remarked, "did something spoil you're appetite?" and about all I could say was "grease monkey".
Thinkin' I'm singning out for a spell and enjoying a movie or game of 9-ball or sumpin!
Anyhow, to J.Q.,
All My Best
Thank you. Expect a message shortly. It'll be a copy and paste deal for you so you don't have to figure out what goes where.If you provide me with new image tags I can replace the broken ones.
