Depending on if you have a 4wd or 2wd truck, the control arms are mounted differently. On a 2wd, the control arms are bolted to the frame and use shims to space it away from the mounting surface to adjust camber/caster. On a 4wd, they are adjusted with eccentric cams attached to the mounting bolts. As the bolts are turned, it pushes and pulls the respective bushing in or out.1st post.
How do you adjust the camber and castor?
88 s10 blazer 4.3
