1 - 15 of 15 Posts
Long Bed Member
yea ive heard about this but i have never seen it done so id like to know too (honestly i dont remember what the sunbird cluster looks like either lol) so if anybody has pics or info post it!
The God of Death
what years of sunbird can this be done with?
Discussion Starter #8
Actually, I got everything out of my sunbird and in doing so realized you need an electronic speedo sensor input. I guess you have to have a 89 or newer truck unless you want to buy the signal convertor.
I also noticed the cluster was wider than the dash opening on the s10, but I didn't take my s10 apart since I couldn't use it anyway.
My speedo was from an 88 sunbird. The only difference with the picture posted was my speedo only went up to 85.
The pic I posted was actually a Marlboro Syclone. I have been told that is the same cluster that was used in the Sunbird but I haven't seen one to know for sure. I am planing on hiting the bone yards the weekend after Mem. day so I'll do a little research then.
The turbo Sunbird was, in fact, the cluster used in the Syclones and Typhoons. They used a set of brackets and a wider housing that held the cluster. It will not fit in a factory S10 cluster. If I remember right, didn't the Sonoma GT's come with the same cluster but without the boost gauge??
Ryan
Yeah the one that was in the Sy/Tys was the same as the turbo sunbird. The only way to do it is to use a peice of the guage shroud(the peice that goes around the guages and sticks out at you) from a Sy/Ty. :thumbdown
so the cluster that is in that pic can be installed in an 89 and up s10 if you use the guage shroud from a syclone or typhoon? does it matter what year on the sys/typ?
4x4 S10
Im with diablo. If it does not take that much then can some one explain it in depth. With a parts list...
1 - 15 of 15 Posts
