This is a little strange but I'm getting a fluid leak around the ac condensor but it's not refrigerent, its radiator coolant. The leak is coming from the condensor cover the large plastic cover on the left side of firewall where the ac lines attach to the (I think) condensor. But again it's Coolant not refrigerant. I thought it was the heater core but the heater lines go into the middle of the firewall instead this leak is on the left side. AC works fine but does smell like coolant. If it were the AC leaking it would not get cold. Right?
Thanks for any help
Heater core is probably leaking and coolant is running through the HVAC box and coming out the AC condensate drain. Sorry
RicG
I was afraid of that. Guess I'll bypass the heater hoses coming out of the firewall until I can get a new heater core and the temp. outside gets cooler. Don't see having to use the heater for sometime, specially living in Southern California.
