If i wanted to convert my truck to straight axels, its currently 2wd, could i use stuff off of an older toyota truck, ie springs, brackets t-case ect.ect......? Need lots of info here
You could go with a set of diffs from a 4 cylinder YJ (the Dana 30 35). The pumpkin is on the driverside and they have 4.10 gears from the factory. Swap in a transmission/Tcase/crossmember from a factory 4x4 S10.
Another <better> option is D44 front from an early bronco. I'd also use the 9" rear from the bronco.
Toyota axles are good, but the pumpkin is on the wrong side.
