Status
Not open for further replies.
1 - 19 of 19 Posts
i know people say that s10 4x4 wheels won't fit on a 2wd s10...is this true? i'm wanting to go prerunner with stock 4x4 wheels. would they fit on a 2wd?
so the lower the off-set, the farther the tires stick out?
blackZR2 said:
Wheel Information
Stock wheel size: 15" x 7"
Stock backspacing: 6"
Stock offset: +2.5" (63.5mm)
Pattern Circle Diameter: 5x4.75" (120.65mm)
Thread size: 12mm x 1.5
Pilot diameter (center bore): 2.75"
Those are the specs for a ZR2. Didn't he ask for the info on a 4x4 (non Z)? or are they the same?
hey everyone,
im trying to throw aftermarket wheels and tires on my 03 zr2 and was looking at wheel specs... and wondering if black rock 15x8 rims can fit 31x10.50R tires on it and still have good clearance without lifting or trimming the fenders?
if anyone can help me out itd be greatly appreciated
I have a 2001 4X4 S10 and i wanna get AR23 wheels with 31x10.5 tires. The wheels are 15X7(same as stock) but the offset is -6mm and the backspacing is 3.76. Does anyone know if they will fit/ how they will fit. I know the tires probably wont fit without a small lift/leveling kit, im just worried about the offset and backspacing. Thanks
so whats the front hub diameter and where do i go to get wheel spacers because all the ones im seeing say they dont fit on the front hub
1 - 19 of 19 Posts
Status
