Not Banned
easiest way is to just rip off your dash, so what if it get cracked, just talk to a person that jacks car stereos.
jk man, just take the dash apart. it has clips, and also some screws, its very easy..!! i think there 7mm..
Hen oida hoti ouden oida
leave it parked in teh Ghetto in front of 7-11 with teh windows down......
(again with the kidding, there are several screws on the lower part of the dash that have to be removed. once those are out, apply a gentle pulling motion to the edge & it should kinda pop out. Be sure to keep an eye on the length of the cable for your airbag cut-off switch & headlamp switch. It also is helpful if you have the tilt steering to put it in the down positon (if you don't, be hella careful with the hazard switch.... good luck!!
[ADDITION].... just got to thinking about it.... there's also a bolt/screw right up on teh dash bezel above the speedo, you'll need to remove that one, too
forum idiot
there is a 7mm under the dash above the gauge cluster...then take out the two of the dash panel to the left and right under the steering column...pull that down...but not hard...just enough to get to the screws for the dash bezel...take out the two 7 mm screws one the left and right of the column...pull the bezel out....now unplug the headlight harness and airbag harness...lift and remove bezel...now remove the three 7 mm screws that hold the radio in and unplug the radio...and you are done...
