what all has to be done to the steering column when swapping the engines? I'm trying to get everything situated right so i can go ahead and knock this puppy out
340555
time to get cereal
I would compare the steering column cutout to a later model. They have the cutout further to the driver's side. You'll most likely be welding that hole up and cutting a new one. Probably involves other steering parts changing as well.
Or you could start with a later model truck and not have to go through all of the work.
Well this would be the first swap in an old s10 like this for me so its all new. I might have to get someone to help me out with the cutting and welding on that one or see if there are any alternatives
