Bowtie Supply, RIP
On my '02 ZR2 X-cab, When you turned the truck off, the radio still played until you pulled a door handle, which I'm pretty sure is how it should work. NOW, when I turn the key off, the radio turns off. If I turn the key backwards to the Accessory position, the radio plays but the buzzer like a doorbell sounds--the sound you get when you leave the keys in the ignition and open the door to leave. THAT sound!
So why doesn't the radio play when I turn the truck off (like before I pull the door handle?)
And why do I get the ding-ding-ding-ding when I turn the key to ACCY?
Thanks for any help.
time to get cereal
Sounds like one of your door ajar switches is broken.
Bowtie Supply, RIP
Thanks, I'll have to figure out how to test that; nobody uses the passenger door, don't know if it would be the problem, or if I can rule that one out...
Bowtie Supply, RIP
I was thinking about this... if the door switch was bad, wouldn't the dome/mirror light try coming on?
