Re: Steering column mounting to firewall
I found out that 1982 thru 1990 the lower mounting bracket to the firewall are the same but from 1991 up they are differant so if you change cabs like I did beaware of this so you get the right columns for your cabI just swapped cabs for my S10 went to a 1985 cab and used all the wiring harnesses from the 1993 S10 I had swapped the cab on, getting to the steering column I found that the mounting on the ends of the column are differant, do I need to disassemble both shafts to swap out the end tubes to fix the misallaingment or does some one have an easier way to do it? Im sure someone else has come up with this same situation before, any help would be appreciated thanx,
