So you can't hit your steering stops with you current Pittman are after your sas. So what are your options different pitman arm , longest you can get is 7" , so then your looking at a custom arm. But there's another option and it won't cost you any thing but a little time/ and some power steering fluid maby a gasket set if your box is leaking.
Step 1 remove you power steering box from your truck
Step 2 remove the snap ring from the end cap, there is a hole at the end where the cap is drive a punch in the hole then work the snap ring out with a flat screw driver.
Step 3 turn the input shaft tell it forces the cap out. Stop
Step 4 make sure you have your box a catch pan becuse there's 24 ball bearing you don't want to lose.
Step 5 remove the 4 9/16 bolts from the top cap center the steering box and tap the steering shaft out from the bottom of the box.
Step 6 now you can turn the input and remove the piston.
Step 7 mark the housing, lock nut and input, loosen the lock nut and then tap the input out with and punch using the 2 holes in the threaded input
( make sure you mark every thing well it need to go back exactly where it was factory)
Step 8 now you should have a empty hosing. ( good time to drill and tap your box for hydro assist ) but if you look inside your box you will find a spacer
Remove it and measure it. Mine was .110 .. now the end cap on the box take it and remove .110 from it.
