1 - 11 of 11 Posts
!! TALK NOW !!
Ok.. ive searched around on here and yahoo and what not and i need to know...
what are the standard sizes of the brake lines.. i have seen where no one replies to ppl's threads about this and there is no sticky or anything to fallow
i have completely ripped my brake system out and starting from scracth.. i have the lines from the abs left.. that is it
i need to know what size lines to run to front brakes and to the rear..
help a guy out.. thanks
!! TALK NOW !!
i would go measure it in a sec.. but i threw them away a yr and a half ago when i started this project cuz I knew I was using new line.
I talked to a budy.. He said the front is 1/4'' and the rear is 3/16'' sound right?
!! TALK NOW !!
Discussion Starter · #9 ·
WELL .. since no one ever wants to help ppl out with numbers.. i found out
the line that runs from the abs (or how ever you do it) to the rear of the truck is 1/4''
the rear lines are 3/16''
the abs lines are 1/4''
I Like Fire....HaHaHa
All brake lines, I should say hard brake lines are all -4AN or 1/4". That includes all lines up front, all lines on the abs and the long main line to the rear. The only 3/16 brake line or -3AN line are the 2 short runs physically on the axle from the 'T' to each drum.
1 - 11 of 11 Posts
