Discussion Starter #1 (Edited by Moderator)
Looking at trying to start this engine, 2000 2.2L 5sp. It cranked while truck was together but fuel tank had been pulled so never heard it run.
Should have most of the harness including the ignition switch.
Anyone have a link to a ECM pinout showing the minimum inputs needed to run?
time to get cereal
You'll need pretty much the entire harness for it to start. It has an anti-tampering system on it called passlock. You will need the BCM, PCM and ignition switch for it to run.
time to get cereal
Ouch. I don't mind the 2.2L, especially now that my truck is under 3000lbs and has a few mods to help high RPM power and throttle response. A tune would probably help too, haven't gotten around to it yet.
I try not to think about the fact that my Fiesta gets the same amount of HP from 1.6L and is still quicker even with less torque... not to mention likes high revs way more than the 2.2L
