Tool Fan
I have a 98 s10 with the extended cab and v6. I have the front dropped with 2" spindles and 3" coils, it is all good their. I have the back dropped with 3" angled blocks and 3" drop leafs. The back is actualy dropped more than 6". Seems to have went down 8", but I did not measure. My problem is the u-bolts that came with my blocks are rusted and will be really hard to get out. I have belltech blocks before and they did not rust. Does chassis tech not make stainless steel u-bolts? Another question I have, I plan on putting 1" or 2" blocks to level the truck out, those do not need to be angled, correct?
Tool Fan
I do have a frame notch, I got one that is way too big, I bet I could lay frame on 20"s with it, it stick up above where the fender wells were.
Tool Fan
So, make sure I understand this, 3" drop leafs should need a 1" angled block correct? Don't want to **** this up again....
