what is spring wrap that 4 '' blocks can cause. and why does it affect acceleration
C Carbon Copy · Steel Chariot Customs Joined Aug 18, 2001 · 4,208 Posts Discussion Starter • #1 • Feb 19, 2002 what is spring wrap that 4 '' blocks can cause. and why does it affect acceleration
Twin-10s · Sold Joined Dec 15, 2001 · 4,592 Posts #2 • Feb 19, 2002 its the wheel hop that you get on a hard take off. 4 inch blocks won't cause it they will make it a little worse though. you probably allready get some wheel hop now. the bigger the blocks the more leverage they will have to make it worse.imo
0 00 Blk-Xtreme · 2 Da Xtreme Joined Jul 17, 2001 · 360 Posts #3 • Feb 19, 2002 Spring W R A P.............! Spring wrap........! the right tire is literaly lifting off the ground.....! the late 60's Cars staggered the shocks to help cure this problem..! would it be possible to put traction bars on is your truck to low.... ?
C Carbon Copy · Steel Chariot Customs Joined Aug 18, 2001 · 4,208 Posts Discussion Starter • #4 • Feb 19, 2002 how does the right tire come off the ground?
