I have a 2000 X-treme that I had to replace the top door pin bushings on the drivers side. The problem is I can't get the damn spring back into the door. I had to pull the spring out to knock out the pin but you cant put the spring back in till the pin is in. And that springs pretty heavy duty I tried compressing it holding it with zip ties but all that ended up doing was putting me on a treasure hunt to find the spring when they broke. Any ideas?
