This is so funny because when I lowered my truck last week we didnt bother with the alignment since the new wheels and tires/alignment was happening the next day. I had to drive home 25 miles and it was probably the most dangerous 25 miles of driving I have ever done. With 2" spindles and 1" spring the toe out although not visually obvious was way out. If I turned at more than 0 G the truck went straight. 45mph corner at 35 and the front end chirped em all the way through the turn. LOL. Put some toe in if you have to drive it anywhere after lowering, or if your not VERY careful you'll drive your truck straight into some one or something. Talk about push. Whew. I was glad to get the 235/55/16's on there with a proper alignment. Like Night and day.
quote:
Originally posted by Spaceman
spindles are also good cause your alingment will no be messed with and you will not ware down just one side of your tire
whoever told you that BS is stupid!!
You will HAVE to get your truck aligned or buy new front tires every month.
