1 - 2 of 2 Posts
when installing spindles do you just switch out the spindle, that takes removing hte ball joint and other stuff....do you have to repack the bearings? should I get new bearings and seals....or dont worry about repacking...just add soem grease...what kind?
blocks.....can you do those one side at a time or do you have to take it all apart?
lastly....
does anyone know a place that could put these on and align in the savannah ga area?
thanks guys
GROUND ZERO - NW Chicago
Just swap out the spindles...I used the stock bushings...Just rregrease them. You can add blocks one side at a time.....That is the easy way to do it.
You will have to get it alignment right away.....Mine droped so far w/cols and spindles that I had to buy new tires. so be careful...Of course I bagged it 2 weeks later so Hey.
Allen (Pres)
GROUND ZERO :bash:
1 - 2 of 2 Posts
