1 - 12 of 12 Posts
I have a 1999 chevy s10 5 speed 2wd I can't find a 3in spindle lift for 1999 but found one for 1998 will it work or did they change the front end on the 99s? Also will I be able to clear 31x10.5 or 31x10s? If not what's the biggest i can go without trimming or adding a body lift thanks in advance
Ok so now that I know the spindle will work does anyone know the biggest tires I can go on a 3in spindle because I've seen s10s with just spindle lifts run 31×10.5 and no body lift but somewhere on here I saw something that said different
· Awww..you ain't got shit!
1984 S-10. Modified
If your truck is stock engine, you should factor what size tires you get. My truck has a high performance 3.4 and just going to 235/75/15 from 235/60/15 made a dent in the truck's power. It's fine, but I wouldn't want 30" tires on it simply due to the power loss. Maybe if I changed the rear to 3.73 gears.
· Been there Done it
On those spindles make sure you aren't looking at S10 Blazer parts. In 98 the Blazer started using a different spindle than the 2wd pickups.
On bigger tires be careful when using anything but stock wheels because off set and backspacing on aftermarket wheels is all over the map and will cause more rubbing problems than the tires. With 2wd stick to 0 offset wheels.
If you have 2.8, 31 inch tires will feel like you are dragging an anchor. If it's a 4.3 it'll just feel gutless. If it's a Tutu, forget those big tires.
1984 S-10. Modified
The lift spindles for the 98 Blazer are made out of unobtainium. Actually they may be made of dontexistanium. I can't say I've ever seen any. I was considering lifting my truck another 2 inches and putting 30" tires on it, but the fact is (at least to me), the truck's track and that height aren't a good combo for handling and probably outright dangerous like that. 235/75 is plenty big. So I opted for Blazer spindles on the front cause the brakes suck.
And you're right on about the tires too. My 91 with a 2.8 had like 215/75/15 on it one time. It couldn't make it up hill on the interstate in 5th. Terrible. I could only imagine what 30" tires on that turd would have been like. My current truck, the 84, with the EFI 3.4 and 3.42 gears, does pretty good with the 235/75/15 on it, but you can tell it certainly stole a lot of power from the truck vs when it had the 215/60/15 on it (too small I know). You could get it sideways pretty easy flooring it easy coming out of a turn, so for daily driving it's actually more civilized with the big tires. Stock? No way. That thing with the 2.8 and the stock carb? That would have been pathetic as ****... I bet it couldn't have managed 60mph on the interstate. What a turd that truck was with the 2SE.
1 - 12 of 12 Posts
