1 - 2 of 2 Posts
I recently replaced the clutch in my 1998 2.2L 5spd s10 and in doing so was required to remove the wiring harness for the O2 sensor and speedometer etc to remove the transmission. Since then, my speedometers will work once in awhile, but usually only stops working after a human hand comes in contact with that harness at the transmission. Usually it will work again after i unplug it from the transmission and plug it back in a few times. I am rather tired of doing this every time and am wondering if perhaps replacing the entire harness would fix the problem, an if so, what is that harness called?
maybe check for loos wire chafed wire or bad ground sounds like bad wire to me
1 - 2 of 2 Posts
