ok i dont know if it just the wiring or i need a new speed sensor. but the speedo will work sometime and sometimes not, is there anyway i can take it out and check it or anything or if anyone has a clue about what it might be of how to fix it. then lmk
I don't know what the resistance should be across the two terminals, but generally when they go bad the circuit is open anyway. You would need to test it while it's not working though. hook a meter to the two terminals and measure the resistance on the sensor. when the speedo quits does the odometer keep working?
no the odometer will stop to tomorrow i plan to take the plug out and clean up the wires & the terminals hopefully that does it i dont feel like spend almost a $100 to know what speed im at
