1 - 2 of 2 Posts
Hi there;
I was looking to find out who might know what spacer size I would need to mount an 86' corvette rim (16 x 8 w/32mm offset) to an 2000 S-10 2wd with 2" droped spindles and stock springs. I'll be running a 245-45 tire. Thanks.
Catdoctor
2korig said:
Hi there;
I don't know what the offset is,but I have 95 style 16x8 camaro z/28 wheels on my 2000 s-10. I've got 2" dropped spindles and 2" dropped springs on the front and 3"dropped leafs and 1" blocks in the rear. I custom ordered my spacers at 2 5/16" thick. Wheels sit nice inside the fenders, tires rub a little in a tight turn on sway bar. Tire size is 225-60 r16, which will be taller than yours, went with this size to keep speedo right. You might also want to use tape wheel weights to keep from knocking off clamp weights on the inside of the wheel.(from experience). Hope this helps.
1 - 2 of 2 Posts
