http://www.sonicelectronix.com/item_67933_Hifonics-Brutus-BRX1100.1D.htmlIt is a Comp RT 10" 1 Ohm, pushing 300 Watts on a 300.1, RMS is 400 watts, max is 800.
So you hang out here too sometimes huh lol This is also Boomintahoe.had this build for a while, did a write up on it. amp is under false floor. im looking to do another build but not take up so much room, also thinking only one 12" with some kind of a box build that makes it sound like two? any ideas?
Here's my finished enclosure & the stereo setup to date:
Custom AutoCAD-Designed Enclosure
JL Audio 10W3V3-4 subs
JL Audio Slash 500/1V1 & 300/4V1 amps
JL Audio C5-653 in the doors & dash
JL Audio ZR-525 in Q-Logic Kick Panels
Single DIN Eclipse w/ 5V Preouts.
I apologize for the delayed reply, hasn't progressed much since May.I'd like to see this installed in the truck. That's what really matters and looks good too.
No worries. But that looks dam sweet tho...hella clean.I apologize for the delayed reply, hasn't progressed much since May.
If your aware or not, those CT amps have a vibration issue from subs resonance. Meaning, the boards inside are not supported as they should have been, The buildhouse cheated. There's more info if you do a search but wanted to express my readings from car audio forums to ya. Just in case you didn't know.
That looks like a tight fit. Our dashes are very alike....and it fits a 1.5 din well. Did you need a special dash kit to fit a double din? Any mods involved?
