1 - 1 of 1 Posts
Help...
I'm looking at buying a '98 Sonoma extended cab with the 3rd door. Two things are bothering my with this 3rd door, one is that the bottom edge is starting to rust and the 2nd is that there is a bit of play in the door when its shut, also when both the 3rd door is shut and the main door is shut there is some movement and air leakage past the door seals. Is this common or can the 3rd door striker be adjusted to help eliminate the play??
On the rust, can I purchase a lower part of the outer door skin (for 3rd door) to repair it??
Thanks
Royce
1 - 1 of 1 Posts
