Sonoma rear diff leak
492 Views 36 Replies 12 Participants Last post by  Innate
Hey all. I just discovered this fluid mark on the Sonoma's rear diff cover.
Tire Wheel Vehicle Automotive tire Tread
Last I checked the fluid (about a month and a half ago), it was at an appropriate level. Not sure why there’s this wet mark now. Any ideas?
21 - 37 of 37 Posts
New cover, gasket and hardware and she'll be ready to roll. I just the rear gears on my 2000. Cover bolts came out easy.
Suggestion...
Don't know how much life is left in this rig, since it looks like you live in the rust belt (!)
You can buy a cover with a drain plug built in. It may be more than you'd want to spend, but they work very well.
If you are really cheap, you could spray the area with brake clean, sand the bag out of the cover near the pinhole and JB Weld the area. I am sure that would solve your leaky cover.
The key is making sure that the area is oil free.
Hope this helps...
Confucius say: JB Weld work good. :p
Reactions: 1
Confucius say: two part sticky will take care of the icky
  • Haha
Reactions: 1
Your axle tubes look like the 7.625 to me.
ZR2 trucks got the 8.5 inch gears. Most 4.3L v6, 5 speed manual Blazers and Jimmys got it as well. Some 4.3L V6, 5 speed manual pickups got the 8.5 inch gears as well, but that seems to be hit or miss.
Yep, that’s what I was thinking it was. I’ll just piece together online what that GM kit comes with👍
Suggestion...
Hope this helps...
The weird thing about this truck, is that certain things are extremely clean (rockers, frames not scaly etc), but then you have this pretty crusty diff cover. I did think about the JB fix as a stopgap… maybe I’ll do that, until I get parts in.
^^^ I wish I was in Baton Rouge. I have at least 3 covers from different projects that I could send you for free. Just pay postage. I think I may be back there for a few days this coming weekend, if you still need a cover, I'll dig one out.
IIRC, they look like new. Nor rust at all.
HAHAHA Brawndo...;)
Reactions: 1
Thank you buddy. I’ll keep everyone updated on what I’ll do with this/when I get parts👍. Just finished up spraying it down with penetrating oil. Hopefully if I do that for a while, it’ll help
Spray them with some PB Blaster or Kroil oil. Do it several times over a few days. Take care when loosening the bolts, and stay away from impact guns. If you get a little movement…spray them again.
I'm impressed, not many people know about Kroil. It's expensive but worth the cost.
Reactions: 1
True. It’s some good stuff!
Tire Wheel Automotive tire Vehicle Car
Decided to slap some JB on it, as a stop gap measure. Cleaned up/sanded the spot, and just put it on. Hopefully it works fine. I’ll keep everyone posted when I get the new cover👍
Automotive parking light Wheel Automotive side marker light Tire Car
Reactions: 1
😂 😂 Me too. A friend gave me a can a few years ago..works great.
True.
Kroil works amazing, but it smells terrible.
PM me with your address, I'll send you a clean cover.
Reactions: 1
Quick update. Before I went in for the night, I decided to check the diff’s fluid level. It was right up to the top, so at least that’s good. I also looked closer at the moisture spot. And lo and behold, there’s a tiny hole that looks like the diameter of a thumbtack right in the middle of the moisture spot. Definitely the culprit. There also is two little dents, (one of which the hole is in the middle of) on the cover. Now, this would be a very easy fix, just replace it and be done. But, the problem is that the bolts holding it on are in such bad condition, that I fear they’re gonna just either snap off, or the head will completely round. Idk what I’m gonna do. Anyone got ideas? I do have a mig, so if I attempt it, and they snap, I can weld a nut and all that.
We get that perforation here on the coast of ME, in fact my '96 from NC is doing it now. Rust goes in from the outside, we have to replace the cover once or twice in a vehicle's lifetime. An acquaintance blew his rear end because he never knew it was leaking. A quick temporary fix is to gently hand sand/clean it real good, wash with Prep Sol, then use POR-15, and when that begins to tack up, lay an appropriate just-big-enough patch of fiberglass on the pinhole area, then another coat or two of POR, then let that cure long enough. I did one that way years ago and it never leaked again, made it to vehicle salvage day without another leak. Same thing happens with the bolt heads, they rot off round. Before trying any wrenching I use a stout punch and heavy ball peen hammer just in the center and jar the bolt straight on, not an angle or on the edge, to jar any rust bond loose; rust is a crystalline structure that expands as it forms, compresses everything, but does not hold up well to jarring. (Some might think that the punch and hammer are my only tools, not so, but it is one of the selective-use ones, and it can work.) Vise Grip makes an interesting tool for hex heads that can help, like #4LW locking hex wrench. Before putting a new cover on, I remove the factory junk paint, scuff it and coat it real good with Eastwood chassis paint or something good. And new bolts, then hit the bolt heads with a CRC brand waxy undercoating so I can get them off next time.
I just did the same job and wrote up my process for replacing one of the bolts that broke off with a Keensert after I broke off an easy-out in it (if you run into problems...). The thread's in the same sub forum.
Looking at this leak makes me wish I replaced mine, it was very rusted. I just sandblasted and repainted it. Would be nice if someone made these cover plates in stainless, that would look pretty mint polished up.
"....made these cover plates in stainless, that would look pretty mint...."
You got that right. Seems like it would be easy for them, so many things are stainless nowadays.
21 - 37 of 37 Posts
