1 - 2 of 2 Posts
I have a '95 S10 and I was thinking about putting a Sonoma grille with a billet insert in. The Sonoma shell will bolt right up, right? I just want to make sure before ordering the stuff.
Thanks
as long as they are the same corrisponding(sp?) years they will bolt right up.... so a 94-97 will bolt up, and as long as you get the shell with the sealed beams it will be a direct swap.. if you go composite lights then wiring will need to be done
1 - 2 of 2 Posts
