1 - 14 of 14 Posts
i would make the top piece and bottom piece the same size and then subtract for the wood thickness for the 4 other sides. Why is there 3" of space at the bottom?
Captain Obvious
There's that step in the extended cab
Picture goes here \/
1.2xx cubes per?
i closed claculator so i forgot the numbers.. dont forget driver displacement
Captain Obvious
big_taki said:
what do you mean measure twice cut once??? don't measure at all. eyeball it cut it. and if you screwed up just bust out the caulking gun with silicone and go crazy
LOL
Trees would shed tears if they knew how many of their relatives I've put to their demise from only measuring once.
Imperialc00 said:
LOL
no no no
Youre just pre cutting scrap wood
Youve got that drawing all wrong. Obviously you dont know acceptable engineering practice because the top view is supposed to be the top one, the front view is supposed to be below that and the right side view is supposed to be to the right side of the front view. The only thing you have going for you is that the lines all line up. I cant even look at it it hurts my eyes....
Captain Obvious
Discussion Starter #10
*smacks forehead*
Not the penmanship, the MATH! lol
i get 1.23 cu. ft of air space per chamber before driver displacement.
other than that all your numbers look good, unless I am missing something...
Not to whore your thread but
how do you know how much to subtract for driver displacement (say a 12 woofer) ? I can figure out 1 cu ft of air space (sealed box) but don't know how much to subtract for the sub?
Again sorry for whorin'
OK here we go, A good rule of thumb, always take about 10% out for the woofer, its not exact but it gets you in the ball park. as for 12's what you have should work. I like my boxes for 12s alittle bigger, but between 1 and 1.5 is cool depending on the woofer. WIth the smaller box you with have less flutter in the woofer "More control" and harder to blow. Just my 0.02 cents.
Peace,
Just build it, if you dont like it blame it on some else and say your gonna do your way next time.
Audiomentry
Re: Not to whore your thread but
Most manufacture post specs. including driver displacement. Average 12" driver will displace from .06-.09CF.
1 - 14 of 14 Posts
