Well I drained the oil and it was full of gas - I have been cranking the thing a ton over the past 2 weeks with bad spark and bad timing, so makes sense. Plus, this was the first fill & flush after washing out the coolant from doing my intake gasket, so I’m going to change the oil another time or two.
I believe I found my weak spark - the connections on the new coil fit tightly and weren’t fully seated, and I cleaned a few more connections. Spark is blue now!
Hoping that the combination of fixing the spark and getting the gas out of my oil will be just what she needs, it did seem to be too rich to run as it’d fire up most easily with the pedal to the floor, no one particular cylinder is missing or has a worse looking plug and I’ve replaced the FPR & nut kit in my CPI system. Will update tonight
