1 - 2 of 2 Posts
· NVRBDUN
Truck is a 2000 Sonoma stepside that comes with fleetside bed from a 2000 S10.
Roof right over windshield was caved in due to hood flying open which seller did not tell me in advance. I cut out the metal and welded in new and started bodywork. If you can weld I can cut the roof section off the black cab and include it with the truck. You should be able to split the outer skin and change it.
Truck was a 2.2 Auto but now has a 6.0/4L80E from a 2003 Silverado HD.
I also have a black fleetside bed and the front bumber, grill and lights from a 2000 S10.
Automotive side marker light Automotive parking light Tire Wheel Car
Engine in the donor
Vehicle Hood Car Motor vehicle Automotive exterior
In the Sonoma
Vehicle Automotive tire Motor vehicle Automotive design Hood
All new suspension bushings, new brake hardware, new front rotors, calipers and brake hoses front and rear.
New sway bar bushings and end links. Frame cleaned and chassis coated front to rear.
Stripped the frame and painted with chassis paint. Rebuilt everything.
Motor vehicle Hood Automotive tire Automotive lighting Automotive tail & brake light
Tire Wheel Vehicle Automotive tire Hood
Tire Automotive tire Automotive lighting Automotive exhaust Motor vehicle
Vehicle Car Motor vehicle Automotive tire Hood
$2500
1 - 2 of 2 Posts
