1 - 19 of 19 Posts
Likes MOAR Low
hey, i was wondering if anyone has sanded they're factory 98+ s10 airdam smooth to get the wrinkle finish off before painting it ? If so, what all was involved and was it worth it? comments ? suggestions?
i'd hit it!!
the way we do that at work it sand it with 320 to put a good scratch in the airdamn, prime it with a filler primer (92B060 is a good primer) put a three nice coats let it dry and wetsand with 400 and paint u should be good to go. turns out really nice if done right.
Sweet n Low
anybody else care to post how you did it? im about to attempt...
i'm doing a 94-97 airdam. I'm using an orbital sander with 80 grit to sand off the texture, then using 150 by hand. So far its going good...just very slowly. Hopefully the primer can fill in what i miss with sanding.
i'd hit it!!
all u need to do is put a scratch into the airdam, the filler primer will fill the texture, then u wetsand the primer and paint it and it will be smooth.
Yea, i'll prob give up and do that. Sanding just raises texture and makes it REally rough
Sweet n Low
how many coats of filler primer does it take to fill?
i'd hit it!!
usually at work we do three nice coats using 92b060 filler primer. if u attempt to sand the texture off then when u go to prime it , it will hair up real bad because of sanding into the actual airdam rather than just the texture. i can get some pics up tonight.
ol' bodybuilder
Can you expand for this dummy? What brand is the 92b060 filler primer?
Thnx
Some Day
Umm I would clean that really well with soap and water and then plastic cleaner... then you should spray a plastic promoter... and flex additive should be added to the primer
Sweet n Low
i just got done with my second can of filler primer, and its pretty close to filled. after sanding will have to touch up little spots here and there, but its turning out pretty good so far. i heard you can spray the adhesion promoter after primer right before you base coat it. is that correct? and anyone know what brand has that in a spray can? thanks
Sweet n Low
well i wetsanded the filler primer with 400 grit and shot another coat of filler for the imperfections. its going to come out real smooth...and then on to wetsanding again...will have some pics up soon if i can find the digi...
i'd hit it!!
92b060 is a valspar primer it comes with hardner hpc000 and for a gallon it is around 80 bucks for but it is good stuff def worth the money.
1 - 19 of 19 Posts
