sup s10 lovers im new to this forums i got a little problem wit my bag system:
my front driver side bag pressure is reading high but bags are aired out and still reads 60 and the rest are normal 02........???
wats up wit that anyone know?
thanks in advance
whats up man. if its aired out check to see if the line is kinked. the needle on your guage might be taking a dump too. if you have push to connect fittings try changing the guages real quick
wat lines could be kinked?
wat gauges?
sorry i dont know to much about bags i just started to get in to it......
Spare Parts Pack Rat
He's saying to check the air line from the valves to the bag and see if there any kinks in it. As far as the gauge he is referring to the gauge that is still reding pressure when there shouldn't be any. Try changing the gauge out and see if you still are showing pressure when aired out. If not then the needle in the gauge may be sticking or the gauge is shot.
o ok ill check it out.........
only sometimes it does that like this mornin it was all good then later it was doing that again....
ill just do what you guys say
thanks
by the way das S10forums.com have stickers i would run one in my truck if can
