96 Blazer getting a 95 LT1 from a camaro. I am not 100% done but i have pics to share. Some are cell phone pics so there not as clear. Enjoy.
1996 2wd.
The tear out.
One of many test fits.
AC/Heater box notched with plastic and plastic welded.
Both wiring harnesses had to be joined together so both computers could run at the same time. I had many hours in this wiring harness but it beats paying $1000+ for one.
Transmission crossmember notched for true daul exhaust. I welded/boxed it in but didnt get a pic of that. I am running Flowmaster 3 chambers, stock manifolds, and 2 1/4 pipes.
Here is where I am now. I need to finish cleaning everything up a bit and touch up a few spots.
I do have more pics but didnt want to bore anyone with the small stuff. If you want a certain pic let me know i might have it.
DOOR'D FOR HER PLEASURE!
definately applauds you for your install. looks damn good and almost factory with all the "normal" items under the hood. any test drives and/or problems?
Man... i have a '96 and would LOVE to do a 350 or 400 swap... my plans are when the motor blows up (pray it doesnt anytime soon, 213k on the clock!) swap in a 350.... but i despise the wiring that would have to be done..... but i like wiring, so i guess its all good lol.
looks great man!
Thanks guys. I have gave it a test drive or two and everything seems to be working. I still need to get my PCM tuned cause i deleted the EGR, EVAP, and the rear 02 sensor.
The only real problem i have is that i cant figure out why i have no bottom end. When i take off hard the truck is sluggish until it hits about 3500-4000RPM. After that it pulls really hard. I am kinda stumped on this one.
Here is a pic of the fans on the stock 4.3 radiator. Fans are off a 99 Intrepid and are run directly through the PCM. They turn on around 205-210 degrees. When i get the PCM tuned i will get them to turn on around 190.
