Super Moderator
Hello,
I just started to install my sir michaels tailgate handle relocator and the two bolts that hold the handle to the bracket are hitting the other side of the tailgate. Has anyone esle had this problem and what did they do to fix it. thanks
Mini Truckin' = Lifestyle
you might be able to bend the tabs a lil bit
Super Moderator
I fixed it, I went to the hardware store and bought bolts that had flatter heads,
:nono:
then to top it off I screwed it down after I thought it was opening ok and the right side was not going in all the way. So I pulled out the guide rod and bent it to size, now its perfect...........thanks for replying
