Mine hits sides and thats with airshocks.Dj Fx said:yeah no sway bar and a lever set up
i have mono leaf and i have no side to side in the back but with out the sway bar the front hits like mad
No. no. no.NCHEVYHEVN3 said:How many valves do u have. To do side to side u should have 8 valves. If u have the 8 valves then the air won't transfer to each bag and will limit the body roll. Since u have a mono in the back then it will probly body roll more than with a link setup. No need for a spacer in the front thats normal. I am guessing u have 255c bags in the front and 224c bag in the back. Mine doesn't start movin till around 50-60 psi. The 224c will start movin right away because they are bigger and takes less pressure.
With the front bagged (no swaybar) and regular leafs / 3" blocks out back, I could hit sides hella good... people always thought I was bagged all around...Dj Fx said:yeah no sway bar and a lever set up
Well thats right and wrong. It could also depend on what size bags he has. Some people have the 255c bags in the front so they don't have to trim as much of the spring pocket and the put the bigger bags in the back 224c.Southern said:No. no. no.
The reason that it takes longer for the front to rise it that it requires more pressure to raise the front end of the truck versus the rear.
The front bags lift about 2/3s of the weight of the truck.
It's all simple physics.
It doesn't matter what size the bags are. More pressure is required to lift a heavier item. Again, this is simple physics.NCHEVYHEVN3 said:Well thats right and wrong. It could also depend on what size bags he has. Some people have the 255c bags in the front so they don't have to trim as much of the spring pocket and the put the bigger bags in the back 224c.
Dude I have had both size bags in the front of mine. The larger bags are going to lift before a smaller bag. I have a v-6 in mine and the 224c bags lifted up and my driving psi was at 35. With the smaller 255c bags my ride height is 90 psi.Southern said:It doesn't matter what size the bags are. More pressure is required to lift a heavier item. Again, this is simple physics.
I'm not arguing that.NCHEVYHEVN3 said:Dude I have had both size bags in the front of mine. The larger bags are going to lift before a smaller bag. I have a v-6 in mine and the 224c bags lifted up and my driving psi was at 35. With the smaller 255c bags my ride height is 90 psi.
