I have done some searching and maybe I’m blind but anyway…
I want dual setup from headers to exit before rear tires… do they make a kit or just piece together,
I know I want to use thrush mufflers and long tube headers to go with my TH350 but that’s all I know.
Thank you and sorry in advance,
Glenb
theres not many kits of any type for these old s10s.. let alone a v8 swap.
Your best best is drive down to your local exhaust shop and have them weld you up an exhaust how you like it.
Couple of hours and you'll be on your way.
91 base=driver, 94 mid engine=build
Most exhaust shops suck for mandrel bends.
Figure out your angles then piece together your own exhaust.
Cardboard tubing can get you real close without breaking the bank. You can wrap it with tape/paper check diameter in areas that may be close to hitting etc.
Once pieced together you can mark the tube in 3 spots(3, 6, 9 o clock) then weld it or have someone weld it.
I am a big fan of V band clamps. No gaskets and make maintance much easier.
