Beer, Bait and Ammo
is there one that anyone knows of that can handle at least 350hp and that is shorter than a 2002 axel?
or should i just shorten mine and beef it up? <---how much would that cost?
footbraker
If you're going to run slicks/get traction, buy and then narrow a 9" ford, 8 3/4 chry, or a 12 bolt chev. rear and never worry about it again. It cost me $1950 to narrow a 9" and get it in the truck. That covered everthing from the locker to the brakes etc. If you're going to use street tires the stock rear will hold up.
V8 needin' member
yeah, like rhansen said, buy and narrow a ford 9 inch, throw a locker or a spool in it, some good axles, and never worry about it, if you plan on running slicks, its going to destroy your stock rear, and i dont know of a direct fit shorter axle to answer your first question
Beer, Bait and Ammo
oh i see....well i have 22x9.5 on the back on the back of it do yall think it will matter?
22X11's? those should fit on a stock axle with correct back spacing... thats like a 305 width
as for narrowed axle there arent any direct bolt ins... and there is a company i have read about making cuistom ford 9's to fit any application for like 750 -1000 complete.. thats pretty much as cheap and strong as can be had
