heres the deal. my truck is lowered 2 and 3 and once every month or two I haul my atv. My truck hauls the bike no problem, but it bottoms out really easy due to the extra weight. I was thinking of putting air shocks in the back and just filling them up real good each time before I haul my bike. Would this work okay?
Just a member
I assume you a reunning loweredleafs and this is why you lost payload capacity. You can do one of two things. Either replace them with stock leafs and put in blocks to keep payload. Or you can put on airshocks the help with the weight.
no, I just have 3 inch blocks. My bump stops are cut in half and my truck still bottoms out with the atv. Hopefully the air shocks will do!
Just a member
Well if that is the case then airshocks would work. Or cut your bumpstops brackets all of the way off. That will give you another 2-3 inch of clearance.
