1 - 14 of 14 Posts
I am thinking about doing a 3/4 drop on my 02 s10 ext cab. If i do 2"spindles with a 1"coil will I still have to put drop shocks on the front? And are stock shocks still good on the rear with blocks?
nva2low
when you order the shocks make sure you order shocks for 0-2" drop since your using a 1' coil..dont trick yourself on buyin shocks for a 3-5 drop..yes you are lowering your truck 3" up front but your only shortening the coil 1"..i made this mistake lol..belltech nittro 2s are the best shocks btw
Can't fly when your High
slamthiz are you having trouble with you nittros in the rear. Cause i got 6 inch drop in the back and rides rougher than a surfboard.
Under Construcktion!
mm not that i can notice. it takes bumps smoothly. and since i just notched it rides a lot better. have u checked your axle clearance?
axel clearence is pretty short maybe an inch or 2. So you installed the bolt in c notch? from SD? would they be easy to make yourself?
so the truck takes bumps alot better now with your notch?
yeah notches are easy to make yourself, I have one made from 1/4" thick pipe. Do you marks on your frame where the axle hits it? If not you might have the 0"-3" shocks and you're bottoming out on those.. I thought they were suppose to cover 3" leafs but maybe not?
i know my shocks are for a 6 inch drop. I ofter wondered that myself. If i make the notches myself would i need the plates that bolt onto the side of the frame rail? I'm thinking i might. i wish i could get plans so i know how exactly to make them. We got a metal fab shop close to our shop so getting material will be no problem. anyone have a blue print of a bolt in notch?
i bought my bolt on in the classifieds here and only paid 50 bucks shipped and it took maybe and hour or two to get it done
You can, it'll strengthen the frame.
You can run stock shocks all the way around if your doing Spindles 1" springs and blocks.
Ive been running monroe sensa-trac shocks and it rides great. If its cheaper then just go down to the auto parts store and buy some to go with your drop.
1 - 14 of 14 Posts
